how to wait unitl layer creation is complete?
1790
06-22-2017 02:09 PM
andresarias
Hi, I am adding a layer to a map and want to read all the values from a particular field,
await QueuedTask.Run(() =>
                    Layer RefLayer = LayerFactory.CreateLayer(new Uri(LyrFile), myMap);
                    MapView.Active.ZoomToAsync(RefLayer);
                    if (RefLayer == null)
                        ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("Failed to create layer for url:" + LyrFile);
                        return;
                    else
                       //find layer
                      var disLayer = MapView.Active.Map.FindLayers(layerName).FirstOrDefault() as BasicFeatureLayer;
however the FindLayers returns null.
What would be an appropriate way to wait until the creation is done?
Can someone help me solve this?
CharlesMacleod
I cannot reproduce this. It works for me.
A couple of things which may just be copy-paste issues into the post....
1. You add the layer to "myMap"
2. You attempt to retrieve it from MapView.Active.Map? Are they the same?
also
does RefLayer.Name == layerName? I can't tell from your code.
Is the layer a BasicFeatureLayer?
andresarias
Thank you Charles.  Yes, myMap is the MapView.Active.Map and RefLayer.Name is the layerName.
Your questions helped me find out what the problem was: I was handling the creation in a queued task and FindLayers outside that task. I'm new to C# so I haven't really grasped how the queued tasks work. Thanks again!
