How to Unsubscribe/ReSubscribe Dockpane from Event
862
10-24-2017 03:37 PM
MKa
I have a Dock pane, that when it closes, i want to remove the selection changed event.  Then when i reopen it, I want to resubscribe.  Is there a better way to do this than by tracking the subscribed with a boolean?  I don't want it on when the dockpane is hidden, but i want it to be available again when I bring the pane back to showing.  I can't seem to simply unsubscribe and resubscribe like i want because OnShow gets called like 3 times when the pane is loaded and adds multiple Subscribes.
protected AttributeEditorViewModel()
      MapSelectionChangedEvent.Subscribe(OnMapSelectionChanged);
      subscribed = true;
~AttributeEditorViewModel()
      MapSelectionChangedEvent.Unsubscribe(OnMapSelectionChanged);
      subscribed = false;
protected override void OnHidden()
   if (subscribed)
      subscribed = false;
protected override void OnShow(bool isVisible)
   if (!isVisible || subscribed)
      subscribed = false;
else
      subscribed = true;
Tags (1)
UmaHarano
Hi
By using subscription tokens you can subscribe\unsubscribe when the dockpane is visible\hidden. This code below worked for me:
private SubscriptionToken _eventToken = null;
            if (isVisible && _eventToken == null)
                _eventToken = MapSelectionChangedEvent.Subscribe(OnMapSelectionChangedEvent);
            if (!isVisible && _eventToken != null)
                MapSelectionChangedEvent.Unsubscribe(_eventToken);
                _eventToken = null;
        private void OnMapSelectionChangedEvent(MapSelectionChangedEventArgs obj)
            MessageBox.Show("Selection has changed");
Uma
