I have a Dock pane, that when it closes, i want to remove the selection changed event. Then when i reopen it, I want to resubscribe. Is there a better way to do this than by tracking the subscribed with a boolean? I don't want it on when the dockpane is hidden, but i want it to be available again when I bring the pane back to showing. I can't seem to simply unsubscribe and resubscribe like i want because OnShow gets called like 3 times when the pane is loaded and adds multiple Subscribes.
protected AttributeEditorViewModel()
MapSelectionChangedEvent.Subscribe(OnMapSelectionChanged);
subscribed = true;
~AttributeEditorViewModel()
MapSelectionChangedEvent.Unsubscribe(OnMapSelectionChanged);
subscribed = false;
protected override void OnHidden()
if (subscribed)
subscribed = false;
protected override void OnShow(bool isVisible)
if (!isVisible || subscribed)
subscribed = false;
else
subscribed = true;
Hi
By using subscription tokens you can subscribe\unsubscribe when the dockpane is visible\hidden. This code below worked for me:
private SubscriptionToken _eventToken = null;
if (isVisible && _eventToken == null)
_eventToken = MapSelectionChangedEvent.Subscribe(OnMapSelectionChangedEvent);
if (!isVisible && _eventToken != null)
MapSelectionChangedEvent.Unsubscribe(_eventToken);
_eventToken = null;
private void OnMapSelectionChangedEvent(MapSelectionChangedEventArgs obj)
MessageBox.Show("Selection has changed");
Uma
