For a UniqueValueRendererfor point feature layer, I am creating classes using the following :
var uniqueValueClass = new CIMUniqueValueClass
Values = uniqueValues.ToArray(),
Label = compValue,
Visible = true,
Editable = true,
Symbol = new CIMSymbolReference { Symbol = GetPointSymbol(symbolIndex, sizeVal,GetColor(colorIndex)) }
and creating the symbols :
private CIMPointSymbol GetPointSymbol(int symbolIndex, int sizeVal,CIMColor colour)
var shapeDef = GetEsriSymbolTable[symbolIndex];
var cimMarker = SymbolFactory.ConstructMarker(shapeDef.index, shapeDef.font, "Regular", sizeVal, colour); //create marker from the Font, char index,size,colour
cimMarker.Rotation = shapeDef.rotation;
var pointSymbol = SymbolFactory.ConstructPointSymbol(cimMarker); //create a symbol from the marker
return pointSymbol;
The colour is being applied to the fill, but not to the shape outline. How can i set the colour for the outline ?
GetEsriSymbolTable(symbolIndex) returns a tuple with font, character index and rotation ]
Hi Jack,
When you create your CIMMarker, create it as a CIMCharacterMarker. You can then access the "polygon symbol" used to render the marker and then access the SymbolLayers (components that make up the symbol) to change the fill and outline. Here is a code snippet:
var cimMarker = SymbolFactory.ConstructMarker(symbolIndex, "Wingdings 3", "Regular", sizeVal, colour) as CIMCharacterMarker; //create marker from the Font, char index,size,colour
var polygonMarker = cimMarker.Symbol;
//modifying the polygon's outline and fill
polygonMarker.SymbolLayers[0] = SymbolFactory.ConstructStroke(ColorFactory.GreenRGB, 2, SimpleLineStyle.Solid); //This is the outline
polygonMarker.SymbolLayers[1] = SymbolFactory.ConstructSolidFill(colour); //This is the fill
Thanks
Uma Harano
Perfect / Brilliant - thanks for your help !
