How to run an gp service published to ArcGIS Server from ArcGIS Pro SDK?
683
03-03-2023 03:35 AM
Flayner
I published my tool to ArcGIS Server as a GPServer.
I have tried running the tool using await Geoprocessing.ExecuteToolAsync(), but doesnt not work. I would like to know the correct way to run my tool.
tks
My code:
string tool_path = @"C:\Data\Tools\agsfile.ags\Mytool/MyScript";
var gpResult = await Geoprocessing.ExecuteToolAsync(tool_path, null);
When I try use "OpenToolDialog", the message below occurs
Flayner
The problem has been solved.
It is necessary to uncheck the option indicated in the image below when creating the connection.
Flayner
