I would like to retrieve the geodatabase storage type from a specified FeatureClass or Geodatabase.
In ArcGIS Desktop, this was done with the Geodatabase.IFeatureClassStorage. The GeometryStorage property returned a esriGeometryStorage value.
Do we have any equivalent in ArcGIS Pro SDK ?
Any help would be appreciated.
Solved! Go to Solution.
Just a guess: the storage_type column in the SDE_geometry_columns table.
Maybe whatever value is there can be cast to an esriGeometryStorage enum.
Even though SDE_ and GDB_ tables don't get listed, last time I checked they can still be opened and read using Pro SDK methods.
You can check geodatabase connection string:
FeatureClass fc = ...
var gdb = fc.GetDatastore() as Geodatabase;
string connection = gdb.GetConnectionString();
string workspaceName = connection.Split('=')[1];
string ext = Path.GetExtension(workspaceName);
if (string.Compare(ext, ".gdb", true) != 0 ) {
else if(string.Compare(ext, ".sde", true) != 0) {
This gives the GeodatabaseType not the GeodatabaseStorageType.
It doesn't look like Pro provide access to the value. I am curious to know what are you trying to achieve with this storage types? Would you mind sharing few details / code snippets that will help us to understand the issue and recommend an approach?
