How to register as versioned using ArcGIS Pro SDK .NET?
2890
8
04-10-2023 02:04 PM
gisx
How to register a feature dataset as versioned using ArcGIS Pro SDK .NET?
The following is ArcObject codes:
ESRI.ArcGIS.Geodatabase.IVersionedObject pVersionedObject = null;
pVersionedObject = (ESRI.ArcGIS.Geodatabase.IVersionedObject)pFeatureDataset;
if (!pVersionedObject.IsRegisteredAsVersioned)
pVersionedObject.RegisterAsVersioned(true);
Thanks!
Tags (1)
2 Solutions
GKmieliauskas
You can do it by calling geoprocessing:
var mva = Geoprocessing.MakeValueArray(datasetName, "EDITS_TO_BASE");
await Geoprocessing.ExecuteToolAsync("RegisterAsVersioned_management", mva);‍‍
gisx
@GKmieliauskas @JinZ
The RegisterAsVersion GP can only take input FeatureDataset as string.  So the input FeatureDataset object won't work even in the MakeValueArray method.
With GDB connection on the fly, this will do the trick:
DatabaseConnectionProperties connectionProperties = new DatabaseConnectionProperties(EnterpriseDatabaseType.Oracle)
using (Geodatabase geodatabase = new Geodatabase(connectionProperties))
      // Open a FeatureDataset.
      using (FeatureDataset featureDataset = geodatabase.OpenDataset<FeatureDataset>("your_dataset_name"))
		string path = featureDataset.GetPath().ToString().Replace("file:///", "");
		var mva = Geoprocessing.MakeValueArray(path, "NO_EDITS_TO_BASE");
		var gpResult = Geoprocessing.ExecuteToolAsync("management.RegisterAsVersioned", mva);
		Geoprocessing.ShowMessageBox(gpResult.Result.Messages, "GP Messages", gpResult.Result.IsFailed ? GPMessageBoxStyle.Error : GPMessageBoxStyle.Default);
GKmieliauskas
gisx
Thanks @GKmieliauskas !!
gisx
Hi @GKmieliauskas ,
Is there any other way not using Geoprocessing call?
I am using enterprise geodatabase.  If I use Geoprocessing, I have to hardcode the input Feature Dataset's path using sde connection file. I try to avoid that.
Can this be done inside of geodatabase connection? Thanks!
// register feature dataset as versioned
GKmieliauskas
I don't know another way.
Geoprocessing tool documentation here:
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/register-as-versioned.htm
It says that parameter must be Feature Dataset or Table View. There is no matter for Geoprocessing.MakeValueArray if you pass text string or FeatureDataset object. So code could look like this:
           var mva = Geoprocessing.MakeValueArray(featureDataset, "EDITS_TO_BASE");
gisx
Great! Let me try! Thanks for quick response!
JinZ
Does it work for you? It's not working for me
gisx
JinZ
this works, Thanks!
