I was trying to read a CAD feature class from a DWG file but could not find any Pro APIs related to it. Any help will be greatly appreciated!
Hi
Here is a code snippet to add a feature class in a CAD DWG file -
<SPAN class="keyword token">string</SPAN> url <SPAN class="operator token">=</SPAN> <SPAN class="string token">@"E:\Data\CAD\Charlottesville\N1W1.dwg\Polyline"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//FeatureClass of a cad dwg file</SPAN> Uri uri <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Uri</SPAN><SPAN class="punctuation token">(</SPAN>url<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">await</SPAN> QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> LayerFactory<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateLayer</SPAN><SPAN class="punctuation token">(</SPAN>uri<SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">.</SPAN>Active<SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Uma
Hi Uma,
Thank you very much for your help. Is it possible to a CAD file without add it to Map control?
Best regards,
Fayu
Hi Fayu
Do you mean Pro’s Map Control? Yes, should be no problem.
