How to import geojson to arcgis layer in .net
2992
7
10-18-2022 06:39 PM
SIASIA1
How to import geojson to arcgis layer in .net?
I want to convert geojson file to featurelayer in arcgis programmatically using arcgis pro sdk .Net
GKmieliauskas
Sorry. It must be like this:
      var featureClassUri = new Uri(featureClassPath);
      //Define the Feature Layer's parameters.
      var layerParams = new FeatureLayerCreationParams(featureClassUri)
        //Set visibility
        IsVisible = true,
GKmieliauskas
You can use JSONToFeatures geoprocessing tool to convert your data to featureclass then create layer from it. To call geoprocessing you can use code below (for point features):
var parameters = Geoprocessing.MakeValueArray(geoJSONPath, featureClassPath, "POINT");
var gpResult = await Geoprocessing.ExecuteToolAsync("conversion.JSONToFeatures", parameters,
                    null, CancelableProgressor.None, GPExecuteToolFlags.None);
Change 1 line 3 parameter to your data type
To create layer use another piece of code:
var layerParams = new FeatureLayerCreationParams(featureClassPath)
  //Set visibility
  IsVisible = true,
//Create the layer with the feature layer parameters and add it to the active map
var createdFC = LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, MapView.Active.Map);
SIASIA1
How can I filll "featureClass" parameters?
I dont't want make any feature class and gdb using arcgis pro GUI.
Can I create empty featureclass?
2. If my data feature is LOCATION, just fill "LOCATION" in the "POINT" place?
GKmieliauskas
1. Do you mean "featureClassPath"? You can specify shapefile path or use default project gdb and specify prefix for FeatureClass name. You don't need create featureclass. It will be created by tool.
2. JSONToFeatures geometry_type parameter can be one of these:
  • POINTPoints will be converted to features.
  • MULTIPOINTMultipoints will be converted to features.
  • POLYLINEPolylines will be converted to features.
  • POLYGONPolygons will be converted to features.
 So, I think POINT is what you need.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/conversion/json-to-features.htm
GKmieliauskas
For example, to specify featureclass path you can use code below:
string featureClassPath = Path.Combine(Project.Current.DefaultGeodatabasePath, "Locations");
SIASIA1
I tested by making feature class, It successed
Geodatabase gdb = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri("C:\\Users\\hello\\Documents\\ArcGIS\\Projects\\MyProject1\\MyProject1.gdb")));
using (FeatureClass featureClass = gdb.OpenDataset<FeatureClass>("test"))
var parameters = Geoprocessing.MakeValueArray("./result.json", featureClass, "POINT");
var gpResult = Geoprocessing.ExecuteToolAsync("conversion.JSONToFeatures", parameters,
var layerParams = new FeatureLayerCreationParams(featureClass)
//Set visibility
IsVisible = true,
But, when I use string featureClasssPath,  error .
I  attached the error image
GKmieliauskas
        //Set visibility
        IsVisible = true,
SIASIA1
Thanks, I solved it! 😄
