How to implement TableSort to ArcGISPro SDK?
2270
6
08-29-2019 12:06 PM
JamesKennedy1
I have a question on how to implement a TableSort in ArcGISPro SDK
In ArcObjects, the ArcMap SDK, you can do something like this
TableSort tableSort = new ESRI.ArcGIS.Geodatabase.TableSortClass();
tableSort.Fields = refMileField;
tableSort.set_Ascending(refMileField, true);
tableSort.QueryFilter = profileScenarioFilter2;
tableSort.Table = profileScenarioTable.Table;
tableSort.Sort(null);
Later on I use this TableSort in order to give a RowCursor its rows it needs.
What is the proper way I can convert TableSort to a RowCursor?
Or is there another way I need to convert the TableSort to another type?
Thank You
JamesKennedy1
Thanks for taking the time to answer. My solution ended up being
ArcGIS.Core.Data.SortDescription refMileFieldSortDescription = new ArcGIS.Core.Data.SortDescription(refMileActualField);
refMileFieldSortDescription.SortOrder = ArcGIS.Core.Data.SortOrder.Ascending;
TableSortDescription tableSortDescription = new TableSortDescription(new List<ArcGIS.Core.Data.SortDescription>() { refMileFieldSortDescription } );
tableSortDescription.QueryFilter = profileScenarioFilter2;
Table tableSortTable = profileScenarioTable.GetTable();
RowCursor sortedScenarioCursor = tableSortTable.Sort(tableSortDescription);
you can put a Query filter in the TableSortDescription, which merged the two into being kind of a sort query command.
RichRuh
Hi James,
Check out this section in the Geodatabase concepts document; I think it should answer your questions.
--Rich
JamesKennedy1
Thanks I transmuted my code to this....
RowCursor sortedScenarioCursorFromSort = tableSortTable.Sort(tableSortDescription);
RowCursor sortedScenarioCursor = tableSortTable.Search(profileScenarioFilter2, false);
But now I have a new question.
How can I make sure I sort, and run my Query Filter at the same time? They both return RowCursors, but how can I merge Sorting and Searching to give me the correct rowcursor after sorting, then searching.
Thank you.
RichRuh
James,
I think setting the TableSortDescription.QueryFilter property will provide what you're looking for.
--Rich
JamesKennedy1
Thanks that did it!
GKmieliauskas
Hi James,
There is simpliest way to do what you need. Add to your QueryFilter variable PostfixClause and run Search on your table like this:
public async Task SearchingATable()
  try
    await ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() => {
      using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
      using (Table table = geodatabase.OpenDataset<Table>("EmployeeInfo"))
        QueryFilter queryFilter = new QueryFilter
          WhereClause = "COSTCTRN = 'Information Technology'",
          SubFields = "KNOWNAS, OFFICE, LOCATION",
          PostfixClause = "ORDER BY OFFICE"
        using (RowCursor rowCursor = table.Search(queryFilter, false))
          while (rowCursor.MoveNext())
            using (Row row = rowCursor.Current)
              string location = Convert.ToString(row["LOCATION"]);
              string knownAs = Convert.ToString(row["KNOWNAS"]);
  catch (GeodatabaseFieldException fieldException)
    // One of the fields in the where clause might not exist. There are multiple ways this can be handled:
    // Handle error appropriately
  catch (Exception exception)
    // logger.Error(exception.Message);
Sample from ArcGIS Pro snippets:
https://github.com/esri/arcgis-pro-sdk/wiki/ProSnippets-Geodatabase
JamesKennedy1
