How to get the IsChecked.Value from checkbox in addin
1605
10-07-2018 06:11 AM
KarstenRank
I saw this example ProGuide Checkboxes for checkboxes in ArcGIS Pro addins.
I have created a checkbox class in Checkbox1.cs.
But how can I use the IsChecked.Value in Module1.cs? If the checkbox ischecked, a script should copy the project to another place after ProjectClosed state.
Thanks Karsten
UmaHarano
Hi Karsten,
You could create a public static property in the module class and set that to the check box's IsChecked property.
class ProCheckbox : ArcGIS.Desktop.Framework.Contracts.CheckBox
        public ProCheckbox()
            IsChecked = true;
        protected override void OnClick()
            // TODO - add specific customization here as necessary
            //Module1.CheckBoxIsChecked is a public static property in the module class file.
            Module1.CheckBoxIsChecked = IsChecked.HasValue ? IsChecked.Value : false;
            MessageBox.Show($"Checked: {Module1.CheckBoxIsChecked}");
UmaHarano
Hi Karsten,
            IsChecked = true;
KarstenRank
Thank you Uma!
This was what I searched!
