How to enable surface constraints for a las dataset using the CIM?
1538
12-05-2019 01:46 AM
KellyGaussen1
Hi there
I have added a surface constraint to a las dataset but it does not automatically enable the constraint and I am wondering how I could enable it using the SDK?
When I add the surface constraint to the las dataset while it is loaded in the map, the properties get updated but I have to manually go into the properties and select the checkbox to enable the constraint or I have to remove the las dataset and re-add it.
I have used the CIMLASDataset's LASDataseFilter.ClassCode to access and modify the filters selected for the las dataset but I can't seem to figure out how to use the SurfaceConstraints property.
Does anyone have any suggestions or know how to do this?
Thanks.
ClaytonCrawford
The AddFilesToLasDataset tool should turn on the added constraints by default. We're going to treat that as a bug to address.
