How to edit symbol labels of a feature layer?
3834
04-07-2016 08:59 AM
by Anonymous User
Not applicable
I'm looking for a way to programmatically edit the symbol labels of my feature layer (the labels that appear in the table of contents / legend):
For example, let's say I'm assigning a simple unique value renderer to my layer based on a single field:
var fields = new[] {"RENDITION"};
var rendererDef = new UniqueValueRendererDefinition(fields);
var renderer = layer.CreateRenderer(rendererDef);
layer.SetRenderer(renderer);
Is there a way I can then define the labels for these unique symbols?
CharlesMacleod
Hi Luke,
We have to edit the unique value renderer itself, once it has been made. I have provided some code below. Note: I encourage you to look at the samples for the CIM at https://github.com/esri/arcgis-pro-sdk-community-samples/tree/master/Map-Authoring/CIMExamples. I based the code snippet below on the source code in 'CreateCIMRendererFromScratch.cs'. It uses the U.S. States dataset available with the samples.
internal class SetLabelsOnUniqueValueRenderer : Button {
        protected async override void OnClick() {
            var usStatesLayer =
                MapView.Active.Map.GetLayersAsFlattenedList().FirstOrDefault((fl) => fl.Name == "States") as
                    FeatureLayer;
            if (usStatesLayer == null) {
                MessageBox.Show("Please add the 'States' layer to the TOC - with a 'STATE_NAME' field containing state names.", "Cannot find US States");
                return;
            //make a unique value renderer
            await CreateUniqueValueRendererOnStatesAsync(usStatesLayer);
            SetLabelsOnStatesRendererAsync(usStatesLayer);
        private Task CreateUniqueValueRendererOnStatesAsync(FeatureLayer fl) {
            return QueuedTask.Run(() => {
                var uvrDef = new UniqueValueRendererDefinition() {
                    ValueFields = new string[] {"STATE_ABBR"},
                    SymbolTemplate = SymbolFactory.DefaultPolygonSymbol.MakeSymbolReference(),
                    //Simple ramp
                    ColorRamp = new CIMLinearContinuousColorRamp() {
                        FromColor = CIMColor.CreateRGBColor(0, 255, 0, 60),//Green, partially transparent
                        ToColor = CIMColor.CreateRGBColor(255, 0, 0, 60),//Red,  partially transparent
                        ColorSpace = new CIMICCColorSpace() {
                            URL = "Default RGB"
                fl.SetRenderer(fl.CreateRenderer(uvrDef));
        private Task SetLabelsOnStatesRendererAsync(FeatureLayer fl) {
                var renderer = fl.GetRenderer() as CIMUniqueValueRenderer;
                //A UniqueValue renderer has one or more CIMUniqueValueGroups. In this example
                //there is only one CIMUniqueValueGroup (otherwise use a 'foreach(var group in ....)'
                var group = renderer.Groups[0];
                //Each group has one or more CIMUniqueValueClasses - in this case we have one class per
                //STATE_ABBR value. Note: The default value and label are on the renderer itself
                //(renderer.DefaultLabel, renderer.DefaultSymbol) and are NOT in a class.
                foreach (var valClass in group.Classes) {
                    //Each CIMUniqueValueClass has a Label (what you are after 😉 and an array of CIMUniqueValues
                    //As our values are unique, we have one CIMUniqueValue per class.
                    //Get its field value (read from STATE_ABBR) and change the label to be the state name
                    if (valClass.Values[0].FieldValues[0] == "AK")
                        valClass.Label = "Alaska";
                    else if (valClass.Values[0].FieldValues[0] == "AL")
                        valClass.Label = "Alabama";
                    else if (valClass.Values[0].FieldValues[0] == "AR")
                        valClass.Label = "Arkansas";
                    else if (valClass.Values[0].FieldValues[0] == "AZ")
                        valClass.Label = "Arizona";
                    //etc,etc
                fl.SetRenderer(renderer);
CharlesMacleod
Hi Luke,
            var usStatesLayer =
                    FeatureLayer;
                return;
                    //Simple ramp
                            URL = "Default RGB"
                    //etc,etc
by Anonymous User
Not applicable
Just what I was looking for. Thanks Charles.
