How to check if a table row is selected or not with RowCursor in ArcGIS Pro SDK?
1086
01-04-2021 03:19 PM
Amadeus111
Is there way to check if a row is selected when using row by row cursor
using (ArcGIS.Core.Data.Table GNISFTable = (GNISFLayer as FeatureLayer).GetTable())
                    using (RowCursor rowCursor = GNISFLayer.Search())
                        while (rowCursor.MoveNext())
                            using (ArcGIS.Core.Data.Row row = rowCursor.Current)
                            //If row is not selected skip
                                fType =  row["FEATURE_CLASS"].ToString();
                                state = row["STATE_ALPHA"].ToString();
                                county = row["COUNTY_NAME"].ToString();
                                quad = row["MAP_NAME"].ToString();
RichRuh
Hi Oguz,
You can obtain a Selection object from the feature layer, and create a RowCursor based on that.
using (ArcGIS.Core.Data.Selection selectedFeatures = (GNISFLayer as FeatureLayer).GetSelection())
  using (RowCursor rowCursor = selectedFeatures.Search(null))
      //Only selected records will be returned
RichRuh
Hi Oguz,
