How to change data source of Stereo Map
2346
09-13-2023 03:53 AM
BarbaraSchneider2
I'm using the following code to change the data source of the stereo map, but it doesn't work:
await QueuedTask.Run(async () =>
    Map stereoMap = await ProjectUtils.GetStereoMapAsync();
    CIMMap cimMap = stereoMap.GetDefinition();
    var stereoProps = cimMap.StereoProperties;
    WorkspaceFactory workspaceFactory = WorkspaceFactory.FileGDB;
    var fileGdbConnPath = new FileGeodatabaseConnectionPath(new Uri(@"D:\Data\StartProject.gdb", UriKind.Absolute));
    var workspaceConnectionString = new Geodatabase(fileGdbConnPath).GetConnectionString();
    CIMStandardDataConnection mosaicDataConnection = new  CIMStandardDataConnection()
        WorkspaceConnectionString = workspaceConnectionString,
        WorkspaceFactory = workspaceFactory,
        Dataset = "MyMosaic",
        DatasetType = esriDatasetType.esriDTMosaicDataset
    stereoProps.StereoModelCollection = mosaicDataConnection;
    cimMap.StereoProperties = stereoProps;
    MapView.Active.Redraw(true);
 Any help is appreciated, thank you!
NarelleChedzey
Hi Barbara,
It looks like you have forgotten to save the updated CIM definition back to the map.   Remember that a GetDefinition call also needs a SetDefinition call after any updates.
Try adding a  steroMap.SetDefinition call with your updated cimMap before you redraw.
Narelle
NarelleChedzey
Hi Barbara,
Narelle
BarbaraSchneider2
Hi Narelle,
thank you for your reply! It works now. However, I can only set the data source if there already is a data source set. If I manually clear the data source of the Stereo Map and then add the data source again programmatically, nothing happens. Is this a bug?
Thank you,
Barbara
NarelleChedzey
Barbara,
If the data source has been cleared, then you probably need to also set other properties on the CIMMapStereoProperties instance.
Try something similar to the following
protected override async void OnClick()
  Map stereoMap = MapView.Active.Map;
    string path = @"D:\Data\StartProject.gdb";
    var fileGdbConnPath = new FileGeodatabaseConnectionPath(new Uri(path, UriKind.Absolute));
    using (var gdb = new Geodatabase(fileGdbConnPath))
      ArcGIS.Core.Data.Raster.MosaicDataset mDataset = gdb.OpenDataset<ArcGIS.Core.Data.Raster.MosaicDataset>("MyMoaid");
      var mosaicDataConnection = mDataset.GetDataConnection();
      var (leftImageID, rightImageID) = GetStereoImages(mDataset);
      stereoProps.SourceType = StereoSourceType.StereoModelCollection;
      stereoProps.LeftImageID = leftImageID;
      stereoProps.RightImageID = rightImageID;
      stereoMap.SetDefinition(cimMap);
  //        MapView.Active.Redraw(true);
// Find the left and right image IDs from the mosaicDataset
// This is achieved by querying the stereo table and retrieving
// the ImageID1 and ImageID2 fields.
(long image1ID, long image2ID) GetStereoImages(ArcGIS.Core.Data.Raster.MosaicDataset mDataset)
  var stereoTable = mDataset?.GetStereoTable();
  var stereoTableDef = stereoTable?.GetDefinition();
  if (stereoTableDef == null)
    return (-1, -1);
  var image1Fld = stereoTableDef.FindField("ImageID1");
  var image2Fld = stereoTableDef.FindField("ImageID2");
  if ((image1Fld == -1) || (image2Fld == -1))
    return (-1, -1);
  long image1 = -1;
  long image2 = -1;
  using (var cursor = stereoTable.Search(null))
    if (cursor.MoveNext())
      using (var row = cursor.Current)
        var image = row[image1Fld];
        if (image != null)
          System.Int64.TryParse(image.ToString(), out image1);
        image = row[image2Fld].ToString();
        if (image != null)
          System.Int64.TryParse(image.ToString(), out image2);
  return (image1, image2);
You may also need to set the LeftImageColorizer and RightImageColorizer properties, but I am not sure.
Let me know if this still doesn't work for you.  It worked for my test scenario, but I am not a raster expert.
Narelle
BarbaraSchneider2
Hello Narelle,
this works! I don't need to set the LeftImageColorizer and RightImageColorizer. Thank you very much.
Barbara
