I am tasked with writing an addin for Pro, what is the recommended way (if it exists) to create settings for the add in that will hold from session to session, but could be changed by the user any time? I'm developing this in VS2015 C#.
There is a new ProGuide: Custom Settings that walks you through how to create custom project and application level settings using an add-in.
Uma
do you mean something like setting default values for inputs?
It is a standard option in most development environments
Uma
