This question was posted recently by Ted Chapin @Ted"How do you get the map coordinates of a tool's click location?"
Here is a code snippet to do this:
protected override void OnToolMouseDown(MapViewMouseButtonEventArgs e)
if (e.ChangedButton == MouseButton.Left)
e.Handled = true;//Let Framework know we want to handle MouseDown asynchronously
private MapPoint _lastClickedMapPoint = null;
protected override async Task HandleKeyDownAsync(MapViewKeyEventArgs k)
_lastClickedMapPoint = await QueuedTask.Run(() => ActiveMapView.ClientToMap(k.ClientPoint));
//TODO - do something with _lastClickedMapPoint
Thanks
Uma Harano
ArcGIS Desktop SDK Team
GeoNet fail! If you have a question, don't ask a question - start a discussion!
Having a hard time translating this to VB. Need to inherit from MapTool, correct? Can't get the HandleKeyDownAsync function syntax.
The templates in Visual Studio are available in C# and VB.NET. Even though most of the examples and snippets are C# VB.NET is fully supported in the VS environment.
Ted, try this (from http://converter.telerik.com/)
It's making more sense now. Part of my problem was that when you override a method like HandleKeyDownAsync, Visual Studio autocomplete inserts "Return MyBase.HandleKeyDownAsync(k)". But once you make the function async, the return statement becomes invalid. It's not needed. Autocomplete is not detecting the async keyword very well.
There's a good sample in the ClientToMap method docs that is exactly what I was looking for:
Does this work, or should we be using
HandleMouseDownAsync instated of HandleKeyDownAsync?
protected override async Task HandleMouseDownAsync(MapViewMouseButtonEventArgs e)
//Convert the clicked point in client coordinates to the corresponding map coordinates.
mapPoint = await QueuedTask.Run(() => MapView.Active.ClientToMap(e.ClientPoint));
What is needed is a code example of the basic process of 'selecting tool from list (e.g., a combobox)', then click on map to get coordinates, then do something with them (e.g., display coord in pop-up). This is not provided as a code snip it in the SDK help documents.
BASED on the new sample published on GeoNet (7/2016) they are using:
protected override void OnToolMouseDown(MapViewMouseButtonEventArgs e) { .. }
and
protected override Task HandleMouseDownAsync(MapViewMouseButtonEventArgs e) { ... }
which appears to work.
Hi Richard,
This sample might help: https://github.com/Esri/arcgis-pro-sdk-community-samples/blob/master/Map-Exploration/BasicMapTool it is displaying the clicked on coordinates.
And this samples has a combo box for the selection of a specific layer: https://github.com/Esri/arcgis-pro-sdk-community-samples/tree/master/Map-Exploration/IdentifyWindow
Hope this helps.
