How do I subscribe a StandaloneTable to a RowCreatedEvent?
576
09-13-2024 10:11 AM
succip
Hello,
We have a variety of datasets in our SDE that need fields auto-populated when a feature's created. My current implementation works fine for FeatureLayers because I can access the Table object when new map views are accessed. I work through all the FeatureLayers in the Map's TOC and subscribe them to events as needed. Unfortunately for StandaloneTables I can't directly subscribe them because they can't be converted to a Table object. Is there any way around this?
Any help is greatly appreciated. My current implementation is as follows:
Module1.cs:
        protected static void OnActiveMapViewChangedEvent(ActiveMapViewChangedEventArgs args)
            if (MapView.Active != null)
                EditorExtension.UnregisterRowEvents();
                foreach (FeatureLayer layer in MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>())
                    EditorExtension.RegisterLayerEvents(layer);
                foreach(StandaloneTable standaloneTable in MapView.Active.Map.GetStandaloneTablesAsFlattenedList())
                    EditorExtension.RegisterStandaloneTableEvents(standaloneTable);
EditorExtension.cs:
        public static void RegisterStandaloneTableEvents(StandaloneTable standaloneTable)
            QueuedTask.Run(() =>
                MapMember mapMember = standaloneTable as MapMember;
                CIMStandardDataConnection cimDataConnection = mapMember.GetDataConnection() as CIMStandardDataConnection;
                if (cimDataConnection.WorkspaceConnectionString.Contains("SDE.DEFAULT"))
                    _rowCreatedTokens.Add(RowCreatedEvent.Subscribe(OnRowCreatedEvent, standaloneTable)); // ERROR: cannot convert standalonetable to table
GKmieliauskas
StandaloneTable has method GetTable() witch returns table object.
_rowCreatedTokens.Add(RowCreatedEvent.Subscribe(OnRowCreatedEvent, standaloneTable.GetTable()));
GKmieliauskas
succip
Oh geez of course, I even do this with the FeatureLayers. One of those days I guess!
Thank you so much for your help. Marked as solution.
