How do I construct a symbol with text within it?
1764
09-20-2023 01:16 AM
ViktorSafar
I want to create a CIMSymbol that will be used in a unique value class renderer. The symbol should be a circle with red fill and the letter R in it.
This is what I have but the symbol comes out as empty and the Symbology tab shows "symbol has inconsistent geometry logic"
var textSymbol = SymbolFactory.Instance.ConstructTextSymbol(ColorFactory.Instance.BlackRGB, 8);
var fill = SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.RedRGB);
List<CIMSymbolLayer> symbolLayers = new List<CIMSymbolLayer>
	new CIMVectorMarker()
		MarkerGraphics = new CIMMarkerGraphic[]
			new CIMMarkerGraphic()
				Symbol = textSymbol,
				TextString = "R"
	fill
_symbolRightLimit = new CIMPointSymbol() { SymbolLayers = symbolLayers.ToArray() };
_symbolRightLimit.SetSize(10);
I have tried to use the Symbology tab to see what I can fix to make it work but it appears that the only way to make that error go away is to add a global effect to the symbol? And while the error went away, the symbol still did not render.
I have also tried to play with the CIM Viewer to see what I can do but have not managed to find anything.
ViktorSafar
I have actually figured it out by using the Symbology pane and the CIM Viewer and lots of back and forth
double size = 10;
CIMColor fillColor = ColorFactory.Instance.RedRGB;
var textSymbol = SymbolFactory.Instance.ConstructTextSymbol(ColorFactory.Instance.BlackRGB, size);
textSymbol.VerticalAlignment = VerticalAlignment.Center;
textSymbol.HorizontalAlignment = HorizontalAlignment.Center;
var fill = SymbolFactory.Instance.ConstructSolidFill(fillColor);
var marker = SymbolFactory.Instance.ConstructMarker() as CIMVectorMarker;
marker.MarkerPlacement = new CIMMarkerPlacementPolygonCenter();
marker.MarkerGraphics[0].Geometry = new PointN().ToCoreGeometry<MapPoint>();
marker.MarkerGraphics[0].Symbol = textSymbol;
marker.MarkerGraphics[0].TextString = "R";
		marker,
		fill
var symbol = new CIMPointSymbol()
	Effects = new List<CIMGeometricEffect> { new CIMGeometricEffectRegularPolygon() { Radius = size } }.ToArray(),
symbol.SetSize(size);
return symbol;
ViktorSafar
Are you potentially replying on the wrong thread?
ViktorSafar
double size = 10;
		marker,
		fill
return symbol;
