Help loading csv table
2316
09-28-2023 05:23 PM
Kevin_Andras
I am in the early stages of converting a very large ArcGIS Desktop Add-In  to the Pro SDK.   My  add-in requires loading of .csv files that are generated by external executables.  These tables have values that ultimately get appended to feature class tables.  I can't figure out how to load .csv files.  Any help would be greatly appreciated.
Thank you!
Kevin_Andras
public async Task<Table> CSVtoTable()   //Task<Table>
            Table tbl = null;
            try
                var container = MapView.Active.Map;
                await QueuedTask.Run(() =>
                    string csvPath = "c:\\temp\\test.csv";
                    string tblName = System.IO.Path.GetFileName(csvPath);
                    var StTable = StandaloneTableFactory.Instance.CreateStandaloneTable(new Uri(csvPath, UriKind.Absolute), container);
                    tbl = StTable.GetTable();
                    var tables = container.GetStandaloneTablesAsFlattenedList();
                    if (tables.Count() > 0)  //don't need this
                        var table = tables.First();
                        if (table.Name == tblName)
                            container.RemoveStandaloneTable(table);
                    using (RowCursor cur = tbl.Search(null, false))
                        while (cur.MoveNext())
                            using (Row row = cur.Current)
                                string id = Convert.ToString(row["ID"]);
                                Debug.Print(id);
            catch (Exception ex)
                ErrorLog(ex.ToString());
                GC.Collect();
                return null;
            return tbl;
I figured out how to do what I needed.  This returns a Table object.
GKmieliauskas
You can load your csv data to featureclass using geoprocessing. Code from ArcGIS Pro SDK Community sample:
      //args for GP Tool
      string input_table = @"C:\Users\uma2526\Documents\ArcGIS\Projects\CustomItemTest\AlaskaCitiesXY.csv";
      var gbd = Project.Current.GetItems<GDBProjectItem>().FirstOrDefault().Path;
      string outputFC = $@"{gbd}\AlaskaCitiesPointConv";
      string XField = "POINT_X";
      string YField = "POINT_Y";
      var sr = MapView.Active.Map.SpatialReference;
      var environments = Geoprocessing.MakeEnvironmentArray(overwriteoutput: true);
      var cts = new CancellationTokenSource();
      //Make the GP Tool arg array
      var args = Geoprocessing.MakeValueArray(input_table, outputFC, XField, YField, "", sr);
      //Execute
      _ = await Geoprocessing.ExecuteToolAsync("XYTableToPoint_management", args, environments, cts.Token,
                        (eventName, o) =>
                          System.Diagnostics.Debug.WriteLine($@"GP event: {eventName}");
                        }, GPExecuteToolFlags.None); //No action is taken, so the new Feature class doesn't get added to the map
Sample is here
RichardDaniels
MVP Regular Contributor
The answer depends on what you want to do with the data. The reply by
GintautasKmieliauskas creates a data source for immedate use with a GP processing. However, if you are just reading a text file into an array to concatenate data, as you mention in your post, you can do it all with standard C# coding. This could be done with the basic old readline, writeline of C or in a modern way using the DataTable data type. If reading from a SQL database table vs. ascii flie suggest using System.Data.SqlClient methods. Simple example at .net - How to read SQL Table data into a C# DataTable - Stack Overflow.
Kevin_Andras
Thanks!  The standard C# method should work...not sure why I never thought of that.
In the old ArcMap SDK it was easy to get an ITable object from a .csv or .dbf file using TextFileWorkspaceFactory or IWorkspaceFactory.  Then I could just step through the table using a cursor.   I was hoping to be able to replicate that.
https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/topic76800.html describes how to create a StandAloneTable, but that's probably more than I need, since I don't need to put it in a container.
Kevin_Andras
            Table tbl = null;
            try
                                Debug.Print(id);
                GC.Collect();
                return null;
            return tbl;
