GetFeatures, IsSelectable, IsVisible
1657
03-04-2022 08:21 AM
Living2Learn
ArcGIS Pro API 2.9
Real basic question converting from ArcObjects(IIdentify) to ArcGIS Pro.
I have multiple layers I need to gather information about.
Using the API community example CustomPopup.
//Get the features that intersect the sketch geometry.
var result = mapView.GetFeatures(geometry);
for (var kvp in results)
if (kvp.Key.Name == myLayer.Name) {// do something}
This only returns layers the end user has set as selectable and display turned on.
I already know I can set them SetSelectable, get current status and setback after MapTool is deactivated.
How to get all layers regardless if they're selectable or visible?
GKmieliauskas
You can iterate through map feature layers and make spatial query:
                SpatialQueryFilter filter = new SpatialQueryFilter();
                filter.FilterGeometry = geometry;
                filter.SpatialRelationship = SpatialRelationship.Intersects;
                var allLayers = map.GetLayersAsFlattenedList().OfType<FeatureLayer>();
                foreach (var layer in allLayers)
                    var featClass = layer.GetFeatureClass();
                    using (var rows = featClass.Search(filter, false))
                        while (rows.MoveNext())
                            using (var feature = rows.Current as Feature)
GKmieliauskas
Living2Learn
Thank you for the response.
Your suggestion was what I ultimately used.
