How do I select a list on a map?
2285
5
03-07-2022 12:58 AM
DavidMrázek
Good day,
in my application I would like to search for some elements in the map, and then add them to the list. After going through all the elements, I would mark all the elements from the list on the map. but I don't know how to choose elements from the list.
Here is a code sample:
 private async Task DeletePolygonInPolygon(CancelableProgressorSource cps, uint steps, FeatureLayer polygonLayer, QueryFilter queryFilter)
            await QueuedTask.Run(async () =>
                var polyCursor = polygonLayer.Search(queryFilter);
                cps.Progressor.Max = (uint)steps;
                cps.Progressor.Message = "Probíhá ";
                List<Row> features = new List<Row>();
                while (polyCursor.MoveNext() && !cps.Progressor.CancellationToken.IsCancellationRequested)
                    cps.Progressor.Value += 1;
                    cps.Progressor.Status = cps.Progressor.Value + @" z " + cps.Progressor.Max + @" hotovo.";
                    var lineFeature = polyCursor.Current as Feature;
                    var polygonGeometry = lineFeature.GetShape() as Polygon;
                    long oid = polyCursor.Current.GetObjectID();
                    var spatialQuery = new SpatialQueryFilter()
                    { FilterGeometry = polygonGeometry, SpatialRelationship = SpatialRelationship.Within };
                    spatialQuery.WhereClause = "OBJECTID <> " + oid;
                    var rowCursor = polygonLayer.Search(spatialQuery);
                    while (rowCursor.MoveNext())
                        features.Add(rowCursor.Current);
                mv.Map.SetSelection(features);//here I dont know,how to write it
                object[] listOfPara = { polygonLayer };
                await StartATask("management.DeleteFeatures", listOfPara);
            }, cps.Progressor);
Thank you
David
GKmieliauskas
You can select direct from layer:
    polygonLayer.Select(queryFilter, SelectionCombinationMethod.New);
}, cps.Progressor);
GKmieliauskas
}, cps.Progressor);
DavidMrázek
Thanks for the advice, but this code definitely won't display the list.
GKmieliauskas
Sorry. I think you will understand that you can select layer by query directly. Full code for your realization could be like this:
                polygonLayer.ClearSelection();
                    polygonLayer.Select(spatialQuery, SelectionCombinationMethod.Add);
            }, cps.Progressor);
DavidMrázek
I understood what you meant, but it's still not. But thank you.
DavidMrázek
I'm sorry, you were right, it's correct and functional, I didn't notice that I was already rewriting things in the code ... Thank you!
