Get reference to view model from child control class
1953
07-28-2022 04:55 PM
PeteVitt
Hi – I’m working with the ArcGIS Pro sdk 3.0 and  have a DockPane view model that contains a MapTool. I'd like to get a reference to the DockPane View Model from the MapTool class code to set some properties back on the DockPane. In the code below I’m getting an error ‘DockPane is a type, which is not valid in the given context’.  Is there a way I can correct this? I’ve seen this work getting a reference to an EmbeddableControl ViewModel in the SequentialNumberTool Sample (https://github.com/Esri/arcgis-pro-sdk-community-samples/blob/master/Editing/SequentialNumberTool/Se...)
using ArcGIS.Desktop.Framework.Contracts;
internal class LandscapeSelectionTool : MapTool
Dockpane1ViewModel _vm;
protected override Task OnToolActivateAsync(bool active)
            _vm = DockPane as Dockpane1ViewModel;//Error occurs here
            return base.OnToolActivateAsync(active);
Thanks
Pete
Tags (1)
CharlesMacleod
"Dockpane" is a type, not a Dockpane instance which is what u are after.
cast the returned value from FrameworkApplication.DockPaneManager.Find("dockpane_id") to your dockpane view model class. For instance:
_vm = FrameworkApplication.DockPaneManager.Find(
                 "ProAppModule1_Dockpane1") as Dockpane1ViewModel;
This is, essentially, the same thing the auto-generated code for the Dockpane item template is doing when it consrtucts its "default" Show method (to activate the dockpane in the first place).
/// <summary>
/// Show the DockPane.
/// </summary>
internal static void Show()
  DockPane pane = FrameworkApplication.DockPaneManager.Find(_dockPaneID);
  if (pane == null)
    return;
  pane.Activate();
CharlesMacleod
/// <summary>
/// </summary>
  if (pane == null)
    return;
  pane.Activate();
GKmieliauskas
I suggest you to use Esri pattern EmbeddableControl. It has tool - dockpane connection realized already. How to use it you can found here:
ProGuide Using Embeddable Controls · Esri/arcgis-pro-sdk Wiki · GitHub
