Get PortalItem status
1455
09-23-2022 05:49 AM
TomGeo
I recently experienced that while trying to create a layer from one of our portal services my AGP crashed. Turned out that the service I requested to create the layer from was stopped on the server.
To avoid that, I would like to check on the PortalItem (Item) status, but I do not seem to have the possibility to do so (Item Class Members). Fingers crossed I am only looking at the wrong place.
Can I check the PortalItem status?
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
Tags (3)
GKmieliauskas
Have you tried CanCreateLayer from LayerFactory?
					if (LayerFactory.Instance.CanCreateLayerFrom(currentItem))
						LayerFactory.Instance.CreateLayer(currentItem, MapView.Active.Map);
TomGeo
Yes, I tried that, but it's still causing an exception right after
Item curItem = ItemFactory.Instance.Create(curService);
if(LayerFactory.Instance.CanCreateLayerFrom(curItem))
    Layer newLayer = LayerFactory.Instance.CreateLayer(new Uri(curService, UriKind.Absolute), activeMapView.Map, 0);
Also when trying to show the service as a layer in the Map Viewer at the portal, the error message returned by the viewer is: The layer cannot be added to the map.
GKmieliauskas
It worked some time ago. So you could place CreateLayer in try/catch block and make return with message on exception:
    try {
    catch(Exception ex) {
        MessageBox.Show(ex.Message);
        return;
It is not elegant way but it works
