Function for writing custom project settings is not called when saving project programmatically
1490
04-15-2020 07:41 AM
BarbaraSchneider2
I want to save some custom project settings (see ProGuide Custom settings · Esri/arcgis-pro-sdk Wiki · GitHub ). When I manually save the project, the function "OnWriteSettingsAsync()" is called. However, when I programmatically save the project using "Project.Current.SaveAsync()", the function "OnWriteSettingsAsync()" is not called.
Is there a workaround for this?
Thanks, Barbara
Wolf
by Esri Regular Contributor
This could be the problem:  when you change your custom settings make sure you set the Project to reflect a dirty status with:  Project.Current.SetDirty (true);
UmaHarano
Hi Barbara
I modified the sample project referenced in that wiki page to save a project using the SaveAsync method. The OnWriteSettingsAsync method was called for me.
Is there anything specific about how you are calling SaveAsync?
Uma
Wolf
