Error installing ArcGIS Pro 2
2791
09-19-2017 04:19 AM
BenHo
Trying to install ArcGIS Pro 2, getting error ArcGIS Pro (8933) This program has got corrupted internal data: it will exit.  Please obtain a new copy. The laptop is running Windows 7 64 bit.  Have tried downloading another copy, no change.  User does have other ArcGIS products installed as well.
JayantaPoddar
MVP Alum
Are you downloading the software from My Esri site? Ensure the size of the downloaded application is same as that shown in My Esri site.
You could also contact your local Esri Distributor for a copy of ArcGIS Pro. If you still face any challenges installing ArcGIS Pro, you need to contact Esri Tech Support for help.
Think Location
XanderBakker
Esri Esteemed Contributor
Recently Esri has published a comprehensive document on downloading, installing, and licensing ArcGIS Pro:
http://www.esri.com/library/brochures/getting-started-with-arcgis-pro.pdf
