Error creating a map in a core host Application
1339
03-14-2022 05:47 AM
AndreasRuloffs2
Hi everybody,
I have to write an console application, that creates an lyrx-File of a wms-service.
I should be able to create a Layer using the Layer Factory, but it needs a map.
So I try to Create an empty Map first.
When I do, I get an Exception:
System.NullReferenceException
HResult = 0x80004003
Nachricht = Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
Quelle = ArcGIS.Desktop.Mapping
Stapelüberwachung:
at ArcGIS.Desktop.Mapping.MapFactory.<>c__DisplayClass5_0.<CreateMap>b__0()
at ArcGIS.Desktop.Internal.Mapping.Utilities.MakeBasicServiceCall[T](Func`1 serviceCall)
at ArcGIS.Desktop.Mapping.MapFactory.CreateMap(String name, MapType mapType, MapViewingMode defaultViewingMode, Basemap basemap)
Unfortunately I have no idea what my error is.
Thank you, for reading
Andreas Ruloffs
using ArcGIS.Core.CIM;
using ArcGIS.Core.Hosting;
using ArcGIS.Desktop.Framework.Threading.Tasks;
using ArcGIS.Desktop.Mapping;
using Microsoft.Win32;
using System;
using System.Collections.Generic;
using System.IO;
using System.Linq;
using System.Reflection;
using System.Text;
using System.Threading.Tasks;
namespace ProCoreHost3
    class Program
        //[STAThread] must be present on the Application entry point
        [STAThread]
        static void Main(string[] args)
            AppDomain currentDomain = AppDomain.CurrentDomain;
            currentDomain.AssemblyResolve += new ResolveEventHandler(ResolveProAssemblyPath);
            if (args.Length != 3)
                Console.Out.WriteLine("usage: CreateWMSLyr <wmsurl> <visibleLayer seperated by commas> <outputfile name");
                Environment.Exit(1);
            String wmsURL = args[0];
            String visibleLayerStr = args[1];
            String outFile = args[2];
            String[] visibleLayer = visibleLayerStr.Split(new char[] { ',' });
            MainAsync(wmsURL, visibleLayer, outFile).GetAwaiter().GetResult();
        static async Task MainAsync(String wmsURL, String[] visibleLayer, String outFile)
            //Call Host.Initialize before constructing any objects from ArcGIS.Core
            try
                Host.Initialize();
            catch (Exception e)
                // Error (missing installation, no license, 64 bit mismatch, etc.)
                Console.WriteLine(string.Format("Initialization failed: {0}", e.Message));
                return;
            Map map = MapFactory.Instance.CreateMap("test", MapType.Map, MapViewingMode.Map, Basemap.None);
            CIMInternetServerConnection serverConnection = new CIMInternetServerConnection
                URL = wmsURL
            CIMWMSServiceConnection connection = new CIMWMSServiceConnection { ServerConnection = serverConnection };
            Layer layer = LayerFactory.Instance.CreateLayer(connection, MapView.Active.Map);
            LayerDocument layerdocument = new LayerDocument(layer);
            layerdocument.Save(outFile);
        static Assembly ResolveProAssemblyPath(object sender, ResolveEventArgs args)
            string folderPath = @"C:\Program Files\ArcGIS\Pro\bin"; //Get this from registry
            string assemblyPath = Path.Combine(folderPath, new AssemblyName(args.Name).Name + ".dll");
            if (!File.Exists(assemblyPath)) return null;
            Assembly assembly = Assembly.LoadFrom(assemblyPath);
            return assembly;
GKmieliauskas
Corehost supports access to GDB and Geometry only. CoreHost application cannot use many of the constructs provided by the ArcGIS.Desktop dlls
Aashis
by Esri Contributor
In addition to @GKmieliauskas , attempting to access any of the ArcGIS Pro UI elements or types in other assemblies in an ArcEngine-like fashion will crash the program.
Details: Corehost Conceptual doc
