I have a standalone table in which I am inserting the records. After the successful insert I need to display a record or multiple records in the attribute pane for that standalone table. For the same I am using the Select operation on that standalone table.
table.Select(new QueryFilter { ObjectIDs = new List<long> { newObjectId} },
SelectionCombinationMethod.Add)
So I have a custom dock pane that first load the data in that custom UI when selection of some specific features from the map since dock pane is subscribed to MapSelectionChangedEvent. After that a custom UI can insert a data in my standalone table. After the insertion of the data, I am selecting those new records from that table.
But since I am adding the selection in the existing selection it is again getting fired by MapSelectionChangedEvent subscription and then again our dock pane code is triggering again.
Is there a way to select/show those new records in the attribute pane without triggering the MapSelectionChangedEvent again as well as without affecting the current map selection as well. So basically in this specific case, select the records to show the data in attribute pane but don't trigger the MapSelectionChangedEvent again.
@Wolf @UmaHarano @GKmieliauskas
