Determine if a dataset is registered as versioned using the Pro SDK
226
2 weeks ago
ujr_esrich
Hi community, I am wondering if there is a way to determine if a table or feaure class in a geodatabase is registered as versioned. With ArcPy, I could use arcpy.Describe("MyDataset").isVersioned (or isTraditionalVersioned or isBranchVersioned). Is there an equivalent in the Pro SDK? I appreciate any hints.
Tags (4)
GKmieliauskas
Sample from ArcGIS Pro API Reference:
public bool IsTableVersioned(Geodatabase geodatabase, string tableName)
    using (Table table = geodatabase.OpenDataset<Table>(tableName))
        // Check table version type
        RegistrationType registrationType = table.GetRegistrationType();
        if (registrationType == RegistrationType.Versioned)
            return true;
    return false;
GKmieliauskas
            return true;
    return false;
Aashis
by Esri Contributor
In addition to @GKmieliauskas, to find a versioning type ( Branch or Traditional),  versionManager.GetVersioningType() should be called. Please refer to the Pro conceptual doc.
ujr_esrich
Hi @GKmieliauskas and @Aashis, thanks a lot, this works fine for me. I must have overlooked Dataset.GetRegistrationType() when I was first looking into this. In my (still limited) experience, dataset.GetRegistrationType() works fine, even if dataset is from a Geodatabase gdb with gdb.IsVersioningSupported() == false; in this case it returns Nonversioned, which makes sense and is convenient.
