Custom Control and colors for dark and light theme challenges
1703
04-27-2023 06:35 AM
Vidar
Hi
I'm struggling to get a custom control to behave like a standard button on the ribbon.
My custom control is basically the same as a medium size button (text and image), a little notification badge appears on the button which is my embellishment and irrelevant to this question so I'll leave that out.
When I mouse over in dark mode it should be dark grey (like other standard controls), but it shows up as a pale blue (I think the same as the light theme).
Also the esri image I have embedded into the button doesn't seem to respect dark mode.
The following image should help explain:
Here is the XAML, which may prove useful:
 <UserControl.Resources>
        <ResourceDictionary>
            <ResourceDictionary.MergedDictionaries>
                <extensions:DesignOnlyResourceDictionary Source="pack://application:,,,/ArcGIS.Desktop.Framework;component\Themes\Default.xaml"/>
            </ResourceDictionary.MergedDictionaries>
        </ResourceDictionary>
    </UserControl.Resources>
    <Grid Width="120" Height="22">
        <Button BorderThickness="0" Background="Transparent"  Command="{Binding CommandShowDataGroups}" >
            <StackPanel Orientation="Horizontal"  Width="120" Height="22">
                <!--Grid only used to overlay the badge over the icon, it uses the same coloumn 0-->
                <Grid>
                    <Grid.ColumnDefinitions>
                        <ColumnDefinition Width="18"></ColumnDefinition>
                        <ColumnDefinition></ColumnDefinition>
                    </Grid.ColumnDefinitions>
                    <Image Grid.Column="0" Margin="2 0 0 0" Source="pack://application:,,,/ArcGIS.Desktop.Resources;component/Images/VariableCategoryKeyUSData16.png" Width="16" Height="16" Stretch="None"/>
                    <ui:BadgeControl Grid.Column="0" Visibility="{Binding IsBadgeVisible}" BadgeControlText="{Binding BadgeText}" BadgeControlColor="{Binding BadgeColor}" Width="15" Height="17"></ui:BadgeControl>
                    <TextBlock Foreground="{DynamicResource Esri_TextStyleDefaultBrush}" Grid.Column="1" Margin="4 0 0 0" FontSize="12" TextWrapping="Wrap" VerticalAlignment="Center" TextAlignment="left" Width="100" Text="Data Groups"></TextBlock>
                </Grid>
            </StackPanel>
        </Button>
    </Grid>
Can anyone assist?
UmaHarano
Button controls have a Pro Style. Can you try adding this style to you button element?
Style="{DynamicResource Esri_Button}"
Vidar
Hi Uma,
I tried this but it does something weird to the padding or margins, see below:
I think this style is meant for buttons on forms, not ribbons (maybe).
Wolf
by Esri Regular Contributor
You are correct the Margins get set by the esri button style.  But you can override the Margins:
            Command="{Binding CommandShowDataGroups}" Style="{DynamicResource Esri_Button}"
            Margin="0">
  </StackPanel>
</Button>
Now you get the same 'theme' behavior as if you use the Button in a Dockpane:
Ribbon - mouseover:
Dockpane mouseover:
