Create fishnet
1674
06-25-2024 03:48 AM
rs_gs
Hi
I want to create a fishnet using the csharp code,Why isn't it generated after the code runs?thank you.
rs
await QueuedTask.Run(async () =>
string out_feature_class = @"F:\data\fishnet.shp";
double cellSizeWidth = 0;
double cellSizeHeight = 0;
long numRows = 10;
long numCols = 10;
string labels = "NO_LABELS";
string template = "DISPLAY";
string geometryType = "POLYGON";
var parameters = Geoprocessing.MakeValueArray(out_feature_class, null, null, cellSizeWidth, cellSizeHeight, numRows, numCols, "",labels, template, geometryType);
await Geoprocessing.ExecuteToolAsync("management.CreateFishnet", parameters);
rs_gs
The problem is solved, two parameters are added(origin_coord,y_axis_coord), and two parameters are modified(cell_width,cell_height).And delete this code:LayerFactory.Instance.CreateLayer(new Uri(out_feature_class), mapView.Map)
KenBuja
MVP Esteemed Contributor
Does the shapefile get created on your drive but isn't added to the map? If so, set the GPExecuteToolFlags enumeration to AddOutputsToMap in the ExecuteToolAsync.
await Geoprocessing.ExecuteToolAsync("management.CreateRandomPoints", createPointsParamsValueArray, null, CancelableProgressor.None, GPExecuteToolFlags.AddOutputsToMap);
Or does it result in nothing getting created? I return an IGPResult from my geoprocessing tasks to check if they're successful.
IGPResult createRandomPointsMessage = await Geoprocessing.ExecuteToolAsync("management.CreateRandomPoints", createPointsParamsValueArray, null, CancelableProgressor.None, GPExecuteToolFlags.AddOutputsToMap);
if (createRandomPointsMessage.IsFailed)
  System.Diagnostics.Debug.WriteLine("Create random points errors");
rs_gs
I  checked the file location,no shapefile (fishnet )was created.
rs_gs
