Create Extension just like ArcMap
956
10-20-2022 05:44 AM
mody_buchbinder
I am developing an Pro application that will control edit events.
I would like to give option to turn of this option.
In ArcMap I would develop code that implement IExtension and IExtensioConfig then the extension "remember" if it is on or off. If it is on it runs the startup. If I am turning it off it will un subscribe to the events.
Here is the docs for ArcMap  https://desktop.arcgis.com/en/arcobjects/latest/net/webframe.htm#AppFrameworkExtensionHowTo.htm
Moving to Pro I used this example: https://github.com/Esri/arcgis-pro-sdk-community-samples/tree/master/Framework/Licensing
I do not have a license for the extension.
I see two problems. First I do not see startup method - what code is running when extension exists?
Then the extension is always turned off, I could not find a way to remember the last state.
FridjofSchmidt
You can implement IExtensionConfig in your Module class and activate/deactivate your events in the State property setter:
public ExtensionState State
	get { return this._state; }
	set
		this._state = value;
		if (value == ExtensionState.Disabled) this.UnwireEvents();
		else if (value == ExtensionState.Enabled) this.WireEvents();
If you want to persist your extension state in the project, you can overwrite the OnReadSettingsAsync and OnWriteSettingsAsync methods:
protected override Task OnReadSettingsAsync(ModuleSettingsReader settings)
	if (null == settings) return Task.FromResult(0);
	var value = settings.Get("MyExtensionState");
	if (value != null && value is string s && Enum.TryParse(s, out ExtensionState extensionState))
		this.State = extensionState;
protected override Task OnWriteSettingsAsync(ModuleSettingsWriter settings)
	settings.Add("MyExtensionState", this.State.ToString());
See also https://github.com/Esri/arcgis-pro-sdk/wiki/ProGuide-Custom-settings. This also explains how to store settings at the application/user level.
