Create definition query for image service
1226
06-18-2024 10:08 PM
mody_buchbinder
I am trying to add an image service with query def.
In case of the feature layer it is part of the FeatureLayerCreationParameters but not in the Mosaic or Raster parameters.
I wrote the code below, did not return any error but did not added the query.
Using the debugger the value of the image layer definition query does not changed after the line that should change it.
Thanks
            var map = MapView.Active.Map;
            string Url = "https://ags111.stltd.co.il/arcgis/rest/services/mos1/ImageServer";
            QueuedTask.Run(() =>
                var rasterCreationParams = new RasterLayerCreationParams(new Uri(Url));
                rasterCreationParams.Name = "modylayer";
                ImageServiceLayer imageServiceLayer =
                          LayerFactory.Instance.CreateLayer<BasicRasterLayer>(rasterCreationParams, map) as ImageServiceLayer;
                imageServiceLayer.SetDefinitionQuery("OBJECTID = 1");
GKmieliauskas
Have you seen that thread?
GKmieliauskas
