Could not load type from assembly - ArcGIS Pro SDK for .NET
3828
04-23-2024 12:20 AM
NausicaaMontanari
Hello,
I'm creating an Add-In for ArcGIS Pro 3.2.2 with Visual Studio 2022 and .NET 6.0 and ArcGIS Pro SDK for .NET; I'm following the guidelines here: https://github.com/Esri/arcgis-pro-sdk/wiki/ProConcepts-3.0-Migration-Guide#install-pro-and-the-pro-...
I also created some WCF proxy clients to be able to call web services in SOAP: https://learn.microsoft.com/en-us/dotnet/core/additional-tools/wcf-web-service-reference-guide#how- to-use-the-extension
Everything works if I call my code from a generic executable, but if I call the WCF proxy client from a button of an ArcGIS Pro Add-In I receive the following error: Could not load type 'System.ServiceModel.Channels.IBindingRuntimePreferences' from assembly 'System.ServiceModel.Primitives, Version=4.9.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'.
In my project I have to use .NET 6.0 but it seems that ArcGIS Pro uses dlls from an older version: 4.9.0.0.
Instead of loading the classes present in the dll: System.ServiceModel.Primitives.dll of my Nuget Package it uses the dll present in: C:\Program Files\ArcGIS\Pro\bin.
This causes me an error during instantiation WCF proxy client to call my web services.
How can I troubleshoot the problem? Is this a bug?
Thanks very much.
Nausica Montanari
2 Solutions
UmaHarano
Pro will use the dependencies it needs from its bin location. ArcGIS Pro 3.3 will be available in a few weeks. This version of Pro uses updated System.ServiceModel.Primitives.dll - version 6.200.XXX. Can you please try using Pro 3.3 to see if your addin works correctly.
NausicaaMontanari
I hope so and I will wait confidently.
Thanks
Nausica
UmaHarano
MarcelŠíp
Hi @UmaHarano, according to Pro SDK documentation,Pro 3.3 requires .NET 8.  So there seems to be the same type of inconsistency between Pro system requirements (.NET 8 ) and system libraries internally loaded by Pro (6.X).
In my opinion this might cause similar problems as with Pro 3.2. What is the reason for library versions in C:\Program Files\ArcGIS\Pro\bin being different from .NET version required by Pro?
NausicaaMontanari
Thanks
Nausica
mody_buchbinder
Any news on this?
It looks like Pro 3.3 that works with .NET 8 is looking for libraries with version 9
NausicaaMontanari
in ArcGIS Pro 3.3.x with .NET 8 everything works.
Nausica
