conversion.ExportFeatures to shapefile with Attribute Table don't work
163
2 weeks ago
SigurdurGesr
I am try to export to shapefile with
Hi
if I try to export  Attribute Table nothing happens  anyone who can help me with this
Dim out_features = "C:\PATH\file.shp"
Dim where_clause = "TYPE = 80"
Dim use_field_alias_as_name = "NOT_USE_ALIAS"
Dim use_Table = "" 'Export Attribute Table
Dim sort_field = "None"
Return Geoprocessing.MakeValueArray(currentLayer, out_features, where_clause,use_Table,use_field_alias_as_name, sort_field)
 Protected async Overrides Sub OnClick()
        Try
            Dim currentLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType(Of FeatureLayer).FirstOrDefault
            If currentLayer.ConnectionStatus = ConnectionStatus.Broken Then
            End If
            If currentLayer.SelectionCount = 0 Then
            Else
                Dim progDlg = New ProgressDialog("Export map" & vbCrLf & "Go get a coffee", "Cancel")
                progDlg.Show()
                Dim progsrc=New CancelableProgressorSource(progDlg)
                Dim outpath = System.IO.Path.GetDirectoryName(out_features)
                If Not System.IO.Directory.Exists(outpath) Then System.IO.Directory.CreateDirectory(outpath)
                Dim valueArray = Await QueuedTask.Run(Function()
                                                          Return Geoprocessing.MakeValueArray(currentLayer, out_features, where_clause, use_field_alias_as_name, sort_field)
                                                      End Function)
                Dim flags As GPExecuteToolFlags = GPExecuteToolFlags.GPThread
                Dim gpResult As IGPResult = Await Geoprocessing.ExecuteToolAsync("conversion.ExportFeatures", valueArray, Nothing, progsrc.CancellationTokenSource.Token, Nothing, flags)
                progDlg.Hide()
                Dim val = If(String.IsNullOrEmpty(gpResult.ReturnValue), $"Error in gp tool: {gpResult.ErrorMessages}", $"Ok: {gpResult.ReturnValue}")
            End If
        Catch ex As Exception
            MessageBox.Show(ex.Message)
        End Try
    End Sub
Thanks
GKmieliauskas
You have missed one parameter 'Field Map'. Try to change line 28 like below:
Return Geoprocessing.MakeValueArray(currentLayer, out_features, where_clause)
Other values are default and optional
For geoprocessing itself you don't need MCT thread (QueuedTask.Run)
