In my Add-In, I am able to create a table and make a chart from the data. I am unable to change the color of the line series. I modified my code from the sample found at
https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/topic21212.html
I had to change several things to make it work with a standalone table.
The chart draws fine, and I am able to change the LineSymbolProperties.Style (e.g. dashed, solid), but changing the Color does not make any difference - it always plots with the default line series color, pale blue.
The entire function that I'm coding uses a MapTool, with which a user can define a line - points along that line are sampled from a raster (typically a DTM) and distance/raster values are added to the table. I ultimately want the line series on the plot to match the graphic line on the map.
private async static void MakeChart(Table table, string field1, string field2, CIMRGBColor lineColor)
string tableName = table.GetName();
var stTable = MapView.Active.Map.GetStandaloneTablesAsFlattenedList().Where((l) => l.Name == tableName).FirstOrDefault() as StandaloneTable;
CIMStandaloneTable cimTableDefinition = null;
await QueuedTask.Run(() => {
cimTableDefinition = stTable.GetDefinition() as CIMStandaloneTable;
string[] fieldString = new string[] { "distance", field1 };
if (field2 != "")
fieldString = new string[] { "distance", field1, field2 };
var lineChart = new CIMChart
Name = "lineChart",
GeneralProperties = new CIMChartGeneralProperties
Title = $"Profile chart for {field1} ",
Series = new CIMChartSeries[]
new CIMChartLineSeries {
UniqueName = "lineChartSeries",
Name = field1,
Fields = new string[] { "distance" , field1,},
// Specify aggregation type
//FieldAggregation = new string[] { string.Empty, "SUM" },
// Specify custom time bin of 6 months
//TimeAggregationType = ChartTimeAggregationType.EqualIntervalsFromStartTime,
//TimeIntervalSize = 1.0,
//TimeIntervalUnits = esriTimeUnits.esriTimeUnitsDays,
// Define custom line color
ColorType = ChartColorType.CustomColor, //SingleColor makes no difference
LineSymbolProperties = new CIMChartLineSymbolProperties {
Style = ChartLineDashStyle.Solid, //can change this
Color = new CIMRGBColor { R = 0, G = 150, B = 20 }, //changing this does not have any effect - plots blue line regardless
// Add new chart to layer's existing list of charts (if any exist)
var newChartsLine = new CIMChart[] { lineChart };
// Add CIM chart to layer defintion
//vvar allChartsLine = (cimTableDefinition == null) ? newChartsLine : cimTableDefinition.Charts.Concat(newChartsLine); //value cannot be null error
cimTableDefinition.Charts = newChartsLine.ToArray();
stTable.SetDefinition(cimTableDefinition);
When I run the sample that I linked to above, it creates a blank chart telling me to select the variables. I then can change the "Aggregation" type in the Chart Properties and it draws the chart...with a GREEN line or whatever I set it to. So it works in that case, but for some reason the Color cannot be changed in my situation. Here's the sample I ran - I had to wrap it in a Queued Task:
internal class buttonTest : Button
protected async override void OnClick()
// For more information on the chart CIM specification:
// https://github.com/Esri/cim-spec/blob/main/docs/v2/CIMCharts.md
// Define fields names used in chart parameters.
const string dateField = "last_review";
const string numericField = "price";
var lyrsLine = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>();
var lyrLine = lyrsLine.First();
CIMBaseLayer lyrDefLine = null;
//tableDefLine = stTable.GetDefinition();
lyrDefLine = lyrLine.GetDefinition() as CIMBaseLayer;
// Define line chart CIM properties
Name = "lineChart",
Title = $"Line chart for {dateField} summarized by {numericField}",
Name = $"Sum({numericField})",
// Specify date field and numeric field
Fields = new string[] { dateField, numericField },
TimeIntervalUnits = esriTimeUnits.esriTimeUnitsWeeks,
// NOTE: When setting custom time binning, be sure to set CalculateAutomaticTimeInterval = false
CalculateAutomaticTimeInterval = false,
Style = ChartLineDashStyle.DashDot,
//var allChartsLine = (lyrDefLine == null) ? newChartsLine : lyrDefLine.Charts.Concat(newChartsLine);
lyrDefLine.Charts = newChartsLine.ToArray();
lyrLine.SetDefinition(lyrDefLine);
Hi @Kevin_Andras ,
Thanks for the question! We've found a bug where in some scenarios the line color does not display correctly when you set the color through the `LineSymbolProperties` property. We are working to fix this bug, but in the meantime as a workaround you can try setting the color through the `MarkerSymbolProperties ` property. Please see the code below for an example of how you would set the color in this manner:
internal class AddLineChartButton : Button
protected override void OnClick()
var lyrs = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>();
var lyr = lyrs.First();
var lyrDef = lyr.GetDefinition();
var xField = "distance";
Name = "lineChart",
Title = $"Chart for {xField} ",
Name = xField,
Fields = new string[] { xField, "price" },
// set line series color with MarkerSymbolProperties
MarkerSymbolProperties = new CIMChartMarkerSymbolProperties
lyrDef.Charts = newChartsLine.ToArray();
lyr.SetDefinition(lyrDef);
Please let me know if this does not solve your problem.
Thanks again,
Chris
That works. Thank you so much!
Awesome, glad to hear! Thank you for following up.
