Change Mouse Cursor
3466
04-04-2022 12:24 AM
KhaledAliMoh
I want to change the cursor pointer when user selects a tool, I got the sample but I don't know what  MapExploration.Resource1.red_cursor is ? I don't know if it is a file, file path or even an object. I appreciate if anyone gives me an explanation or a full example without shortcuts.
Here is the code in the sample:
internal class CustomMapTool : MapTool
    public CustomMapTool()
        IsSketchTool = true;
        SketchType = SketchGeometryType.Rectangle;
        SketchOutputMode = SketchOutputMode.Map;
        //A custom cursor file as an embedded resource
        var cursorEmbeddedResource = new Cursor(new MemoryStream(MapExploration.Resource1.red_cursor));
        //A built in system cursor
        var systemCursor = System.Windows.Input.Cursors.ArrowCD;
        //Set the "CustomMapTool's" Cursor property to either one of the cursors defined above
        Cursor = cursorEmbeddedResource;
        //or
        Cursor = systemCursor;
And here is the link of the sample Change the cursor of a tool.
Tags (3)
GKmieliauskas
You need to add your cursor file to visual studio project as resource. Instead of
"MapExploration.Resource1.red_cursor"
use
Properties.Resources.<your_cursor_resource-name>
GKmieliauskas
use
KhaledAliMoh
I had to add the file -as you said- as resource. This Link also helped to add the file in the wright way.
