Capture the click event for the existing ArcGIS Pro button
1488
01-16-2023 03:24 AM
newbiedotnetguy
I want to capture the changes which are edited for any feature layer.  So in the edit tab when the user edited any feature layer then on clicking on the save button edits will get saved in the database as per the connection string. I want to catch the event of that save button to capture those newly edited changes to use in other place.
From the daml I got the daml id and below is the one
         caption="Save" keytip="SV" extendedCaption="Save edits."
                condition="esri_editing_CanSaveCondition"
                largeImage="pack://application:,,,/ArcGIS.Desktop.Resources;component/Images/EditingSaveEdits_B_32.png"
                smallImage="pack://application:,,,/ArcGIS.Desktop.Resources;component/Images/EditingSaveEdits_B_16.png"
                className="esri_editing_EditingModule:OnClick_SaveEdits" >
          <tooltip heading="Save Edits">
            Save all edits made since the last save.  After saving, you cannot undo previous editing operations.<disabledText></disabledText>
          </tooltip>
So now the save should work as it is and I should also able to capture and use those editable changes?
Any help?
@Wolf  @UmaHarano  @GKmieliauskas
Tags (1)
GKmieliauskas
GKmieliauskas
Look at the Esri community sdk ModifyNewlyAddedFeatures sample. You need to listen editing events. And there is no need for Save button in your daml.
More info about editing events here:
https://github.com/esri/arcgis-pro-sdk/wiki/ProConcepts-Editing#row-events
newbiedotnetguy
These are editing events but I need to capture the click event of Save button in the Edit tab with the edit changes.
@GKmieliauskas
GKmieliauskas
