Call geoprocessing from the ArcGIS Pro SDK and pre-fill the parameters
263
05-09-2024 12:32 PM
jefferson_bzp
Is it possible to call geoprocessing from the ArcGIS Pro SDK and pre-fill the parameters?
Flow:
From a selected element on the map create a custom button where it will open the dockpane of the update subnetowrk geoprocessing for example, when it is opened it will already perform a pre-fill of the geoprocessing fields.
I know it's possible to create a button in the context menu, but I don't know if it's possible to open geoprocessing window via SDK and fill in the parameters.
Aashis
by Esri Contributor
Hi @jefferson_bzp, yes, you can pass parameters to any Geoprocessing tool and execute it from the Pro SDK. Please refer to the conceptual documentsnippets, and advanced code samples
Aashis
by Esri Contributor
jefferson_bzp
Thanks for your help Aashia, I managed to find what I needed from the links you sent me. More specifically, that's what I needed:
https://github.com/esri/arcgis-pro-sdk/wiki/ProConcepts-Geoprocessing#open-the-tool-dialog-in-the-ge...
I appreciate it!
