Binding to an object class property
1284
12-23-2024 03:51 PM
GaryBilotta
Hello.  I am trying to bind to a class property in a dock pane, but am having trouble doing so.  I can bind to a property on the dock pane, but not as part of a class object.  I have read many posts on the internet and it should not be that hard.  Here are snippets of what I currently have.
xaml:
d:DataContext="{Binding Path=ui.AddressEditorDockPaneViewModel}">
<TextBox Grid.Row="1" Grid.Column="0" MaxLength="5" x:Name="HseNo" Text="{Binding Path = pointAddress.HseNo, Mode=TwoWay, UpdateSourceTrigger=PropertyChanged}" HorizontalAlignment="Left" Margin="3,3,3,3" TextWrapping="Wrap" VerticalAlignment="Top" Width="50" BorderBrush="Black" BorderThickness=".75" Background="Transparent"  Tag=""/>
Back-end c# class in ViewModel (AddressEditorDockPaneViewModel) with HseNo property:
public class PointAddress : INotifyPropertyChanged
    public event PropertyChangedEventHandler? PropertyChanged;
    private static string _HseNo;
    public string HseNo
        get { return _HseNo; }
        //set { SetProperty(ref _HseNo, value); }
        set
            if (value == _HseNo)
                return;
            _HseNo = value.ToString();
            PropertyChanged?.Invoke(this, new PropertyChangedEventArgs(nameof(HseNo)));
Create a new PointAddress object (I have added this part in a couple of different forms (form level variable, and form level variable with creating new in the ShowAsync event):
public PointAddress pointAddress = new PointAddress();
Thank you for helping!!!
SumitMishra_016
It looks like the issue lies in how the binding is set up and how the pointAddress object is exposed in your AddressEditorDockPaneViewModel. The key is to make sure that pointAddress is properly exposed as a property in the view model and is part of the data context hierarchy.
In your AddressEditorDockPaneViewModel, make sure pointAddress is a property and not just a field. For example:
    private PointAddress _pointAddress = new PointAddress();
    public PointAddress PointAddress
        get { return _pointAddress; }
        set
            if (_pointAddress == value)
                return;
            _pointAddress = value;
            PropertyChanged?.Invoke(this, new PropertyChangedEventArgs(nameof(PointAddress)));
Update your TextBox binding to use the PointAddress property in the view model
         Text="{Binding Path=PointAddress.HseNo, Mode=TwoWay, UpdateSourceTrigger=PropertyChanged}"
 Please check this also in your xaml.cs , sometimes I also forget:
public partial class AddressEditorDockPane : UserControl
    public AddressEditorDockPane()
        InitializeComponent();
        DataContext = new AddressEditorDockPaneViewModel();
SumitMishra_016
        set
                return;
GaryBilotta
Thank you!!!!!!!  This helped immensely!!!
