Basic Map Tool dev sample fails in ArcGIS Pro 2.1.2
832
05-01-2018 03:14 PM
RichardDaniels
MVP Regular Contributor
Since updating to ArcGIS Pro 2.1.2 a custom Add-in built based on the Basic Map tool example from GitHub is failing. It returns "Exception while waiting for a Task to complete. Caller: ClearFinishedTasksImpl, File: C:\ArcGIS\ArcGISDesktop\ArcGISEditing\ArcGIS.Desktop.Editing\EditLib\Awaitable.cs, Line: 339. See the inner exception for additional information."
Any ideas or pointers on changes in the 2.1.2 SDK implementation that could have brought this about?
Wolf
by Esri Regular Contributor
Hi Richard,
 I have 2.1.2 of Pro installed and tried the 'Basic Map tool example from GitHub' and it worked fine without any problems.  I assume at this point that your add-in problems are caused by some workflow related issues in your custom add-in code.  Without a code sample of the offending snippet we can't get to the source of the problem.  Maybe you can comment out portions of your code until you see the add-in work again.  This should give you an idea as to the offending code snippet.
