ArcGIS Pro Export Layout to Desktop Button
2293
08-03-2023 11:38 AM
WilliamHart1
Hello all - I am trying to create a plug in button in Pro that takes the current layout view and exports the layout to the desktop. When I go to press the button the code runs with no problem but I am not receiving any output. If anybody could help - I would really appreciate it. Thank you.
Code below.
using ArcGIS.Core.CIM;
using ArcGIS.Core.Data;
using ArcGIS.Core.Geometry;
using ArcGIS.Desktop.Catalog;
using ArcGIS.Desktop.Core;
using ArcGIS.Desktop.Editing;
using ArcGIS.Desktop.Extensions;
using ArcGIS.Desktop.Framework;
using ArcGIS.Desktop.Framework.Contracts;
using ArcGIS.Desktop.Framework.Dialogs;
using ArcGIS.Desktop.Framework.Threading.Tasks;
using ArcGIS.Desktop.Layouts;
using ArcGIS.Desktop.Mapping;
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using static ArcGIS.Desktop.Internal.Core.PortalTrafficDataService.PortalDescriptionResponse;
namespace Export_Button
internal class Button1 : Button
protected override async void OnClick()
LayoutProjectItem layoutItem = Project.Current.GetItems<LayoutProjectItem>().FirstOrDefault(item => item.Name.Equals("Layout"));
Layout layout = await QueuedTask.Run(() => layoutItem.GetLayout());
String filePath = "//map.pdf";
// cref: ArcGIS.Desktop.Layouts.Layout.Export
// cref: ARCGIS.DESKTOP.MAPPING.PDFFORMAT
// cref: ARCGIS.DESKTOP.MAPPING.EXPORTFORMAT
// cref: ARCGIS.DESKTOP.MAPPING.EXPORTFORMAT.VALIDATEOUTPUTFILEPATH
// cref: ArcGIS.Desktop.Mapping.PDFFormat.ImageCompression
// cref: ARCGIS.DESKTOP.MAPPING.PDFFORMAT.IMAGEQUALITY
// cref: ARCGIS.DESKTOP.MAPPING.PDFFORMAT.LAYERSANDATTRIBUTES
// cref: ARCGIS.DESKTOP.MAPPING.ImageCompression
// cref: ARCGIS.DESKTOP.MAPPING.ImageQuality
// cref: ARCGIS.DESKTOP.MAPPING.LayersAndAttributes
#region Layout_ExportPDF
//Export a layout to PDF
//Create a PDF export format
PDFFormat pdf = new PDFFormat()
OutputFileName = filePath,
Resolution = 300,
DoCompressVectorGraphics = true,
DoEmbedFonts = true,
HasGeoRefInfo = true,
ImageCompression = ImageCompression.Adaptive,
ImageQuality = ImageQuality.Best,
LayersAndAttributes = LayersAndAttributes.LayersAndAttributes
//Check to see if the path is valid and export
if (pdf.ValidateOutputFilePath())
layout.Export(pdf); //Export the PDF
#endregion Layout_ExportPDF
Wolf
by Esri Regular Contributor
@GKmieliauskas  is correct, you have to call the export method from the MCT.  Your example code worked fine for after i made a few correction and added some error checking:
  try
    LayoutProjectItem layoutItem = Project.Current.GetItems<LayoutProjectItem>().FirstOrDefault(item => item.Name.Equals("Layout")) ?? throw new Exception("Layout not found");
    String filePath = @"c:\temp\map.pdf";
    PDFFormat pdf = new()
      Resolution = 300,
    if (!pdf.ValidateOutputFilePath())
      throw new Exception($@"Invalid path: {filePath}");
    await QueuedTask.Run(() => layout.Export(pdf)); //Export the PDF
  catch (Exception ex)
    MessageBox.Show("Error: " + ex.ToString());
Running the sample code above results in a c:\temp\map.pdf file:
I fixed the ProSnippet so that the Export method is now called from within QueuedTask.Run.
Thanks for pointing this out.
WilliamHart1
Also when changing the filepath an error shows up when pressing the button that shows "ArcGIS.Core.CalledOnWrongThreadException: 'This method or property must be called on the thread this object was created on." on the layout.Export(pdf) line of code. Any help would be greatly appreciated. Thanks!
GKmieliauskas
You need call layout.Export(pdf) on the MCT. It means , it must be enclosed in QueuedTask.Run.
WilliamHart1
Thank you for the response. With that update, there is no map export and the only thing that happens is the script shown below in the output window of Visual Studio. This solution did relieve the "CalledOnWrongThread" error.
"The thread 0x4fe4 has exited with code 0 (0x0).
The thread 0x333c has exited with code 0 (0x0).
The thread 0x5ff8 has exited with code 0 (0x0).
The thread 0x9b8 has exited with code 0 (0x0).
The thread 0x2b10 has exited with code 0 (0x0).
The thread 0x6888 has exited with code 0 (0x0).
The thread 0x563c has exited with code 0 (0x0).
The thread 0x158c has exited with code 0 (0x0).
The thread 0x8b8c has exited with code 0 (0x0).
The thread 0x70cc has exited with code 0 (0x0).
The thread 0x8b3c has exited with code 0 (0x0).
The thread 0x4ea0 has exited with code 0 (0x0).
The thread 0x7694 has exited with code 0 (0x0).
The thread 0x87bc has exited with code 0 (0x0).
The thread 0x7ad0 has exited with code 0 (0x0).
The thread 0x6588 has exited with code 0 (0x0).
The thread 0x7280 has exited with code 0 (0x0).
The thread 0x7610 has exited with code 0 (0x0)."
Wolf
  try
      Resolution = 300,
WilliamHart1
This worked. Thank you!
