Any way to add graphic image from memory to map or layout
1055
06-23-2020 11:53 PM
by Anonymous User
Not applicable
Hi Guys,
I am currently developing an addin which will generate the image from memory dynamically (using system.Drawing c#)
And would like to check is there anyway to load the image into map or layout.
Those images shall represent soil sample information from particular point feature.
I found this method LayoutElementFactory.Instance.CreatePictureGraphicElement , but it can only be usable with file path.
So I have to save memory stream into file temporarily and load as element and delete the file.
Is there any way to load dynamically? Uma Harano
UmaHarano
Hi
Here is a code snippet that worked for me -
      await QueuedTask.Run(() =>
        LayoutProjectItem layoutItem = Project.Current.GetItems<LayoutProjectItem>().FirstOrDefault();
        var layout = layoutItem.GetLayout();
        //Build 2D point geometry
        Coordinate2D coord2D = new Coordinate2D(2.0, 10.0);
        Image newImage = Image.FromFile(@"C:\Users\...\Image.png");
        var stream = new System.IO.MemoryStream();
        newImage.Save(stream, ImageFormat.Png);
        stream.Position = 0;
        CIMMarker markerFromStream = SymbolFactory.Instance.ConstructMarkerFromStream(stream);
        CIMPointSymbol pointSymbolFromStream = SymbolFactory.Instance.ConstructPointSymbol(markerFromStream);
        //pointSymbolFromStream.SetSize(50);
        //create a CIMGraphic
        var graphic = new CIMPointGraphic()
          Symbol = pointSymbolFromStream.MakeSymbolReference(),
          Location = MapPointBuilder.CreateMapPoint(coord2D)
        GraphicElement ptElm = LayoutElementFactory.Instance.CreateGraphicElement(layout, graphic);
        ptElm.SetName("New Point");
by Anonymous User
Not applicable
Hi Uma Harano‌,
CreateGraphicElement method cannot be found in the 2.5 sdk, but I can use CreatePointGraphicElement and solve it.
Can I get advice on how to get the Coordinate2D of mapPoint in layout view.
Normally It is MapPoint geometry for a point feature in mapview /map, but how to locate it in Layout view -> map frame -> map view.
