Adding feature to Pro feature class in hosted service
1185
09-01-2020 11:58 AM
by Anonymous User
Not applicable
HI, I am trying to add create a feature using the rowbuffer and create row functions in c#. I am using the following code to attempt creating the polyline.
using (geodb)
using (FeatureClass fc = geodb.OpenDataset<FeatureClass>("6"))
RowBuffer rowBuffer = fc.CreateRowBuffer();
rowBuffer["SHAPE"] = poly;
Feature feat= fc.CreateRow(rowBuffer);
fc.Dispose();
geodb.Dispose();
I receive the error
A geodatabase exception has occurred.
on the fc.createrow
RichRuh
Hi Jordan,
Is there any error message with the exception?
Generally in an ArcGIS Pro add-in it's better to use the Editor.  This adds your edit to the operation stack for undo/redo and refreshes the map.  An example of creating a feature using the Editor can be found here.
If you do want to use the low-level editing routines, perhaps because this is a CoreHost application, you should adjust your use of Dispose/using and add a transaction as follows:
using (Geodatabase geodb = ObtainGeodatabaseWithCodeYouDidntShow())
  geodb.ApplyEdits(()=>
    using (RowBuffer rowBuffer = fc.CreateRowBuffer();
      fc.CreateRow(rowBuffer).Dispose();  //disposes the row created by CreateRow
    } // using block disposes fc and rowBuffer
} // using block disposes geodb
I hope this helps.
--Rich
