Access to Project without opening in Pro UI
1476
04-04-2019 03:22 PM
AdamDavis
I would like to access a Pro Project programmatically without first opening it in the UI. Is this possible?
I can see with CIM that there is a CIMGISProject object but it is unclear how to obtain that object from a path.
Back in ArcObjects we could open and manipulate an mxd without it being opened in the UI.
Adam
Wolf
by Esri Regular Contributor
Hi Adam,
 The SDK doesn't provide any means to open and manipulate a project without running ArcGIS Pro, however, you can unzip the project file (manually or programmatically) and examine its content.  The content is in XML format including the CIMGISProject.
- Wolf
AdamDavis
Hi Wolf,
Thanks so much for your reply and that is very interesting information which may give me a way of accessing the details I need if there is no other option.
However, I apologise for not correctly wording my question. I want to be able to access a "side" project whilst in ArcGIS Pro without visually opening the project.
In the SDK I can only see Project.AsyncOpen(path) which opens/loads the project within the Pro User Interface. Is there a way from within the ArcGIS Pro SDK to open a project without it opening/loading in the UI?
Akin to ArcObjects
IMapDocument mxdDocument = new MapDocumentClass();
mxdDocument.Open(path);
IGraphicsContainer graphicsContainer = (IGraphicsContainer)mxdDocument.PageLayout;
//Do something
mxdDocument.Close();
Adam
