ArcGIS Pro SDK Ideas
Other Boards in This Place
This widget could not be displayed.
Latest Activity (62 Idea Submissions)
Sort/Filter :
Open
This proposal requests a new method within the ArcGIS Pro SDK for .NET to programmatically open and execute an Esri T...
AnnaGoldenstein
by AnnaGoldenstein Occasional Contributor
in ArcGIS Pro SDK Ideas Last Updated 05-10-2026
1 0
Open
Currently the ArcGIS Pro SDK supports credential management for layers requiring ArcGIS Pro authentication. However, ...
KevinCheriyan
by KevinCheriyan Frequent Contributor
in ArcGIS Pro SDK Ideas Last Updated 06-30-2026
0 1
Under Consideration
Problem Statement:In the Attribute Pane, when right-clicking on actual field values or cells within the bottom grid, ...
RavindraSingh
by RavindraSingh Frequent Contributor
in ArcGIS Pro SDK Ideas Last Updated 02-25-2026
0 1
Open
Provide the ability, either through Pro.settingsConfig or the SDK, to hide/disable the Select by Attributes | Pending...
Jeff-Reinhart
by Jeff-Reinhart Frequent Contributor
in ArcGIS Pro SDK Ideas Last Updated 11-05-2025
0 1
Open
User is trying to edit the geometry by using split and merge methods and trying to capture these operations to change...
AProzuk
by AProzuk Emerging Contributor
in ArcGIS Pro SDK Ideas Last Updated 05-29-2026
4 4
Open
In ArcGis Pro, under "Contents" pane, we need to have -using contextual menu- an "Expand All" and  an "Collapse All" ...
RabahCherchem
by RabahCherchem Emerging Contributor
in ArcGIS Pro SDK Ideas Last Updated 04-16-2025
1 1
Implemented
In visual studio each time we rebuild and test an ArcGIS Pro add-in one should update the <Data> tag.  If you want to...
RichardDaniels
by RichardDaniels MVP Regular Contributor MVP Regular Contributor
in ArcGIS Pro SDK Ideas Last Updated 05-22-2025
0 1
Open
Hi,I think it would be beneficial to have some functionality to be able to scroll programmatically using the ArcGIS P...
ChrisRobles
by ChrisRobles Emerging Contributor
in ArcGIS Pro SDK Ideas Last Updated 03-07-2025
0 0
Open
We would like to request the implementation of AssemblyLoadContext in ArcGIS Pro to improve add-in isolation and prev...
Johannes_Strahler
by Johannes_Strahler Emerging Contributor
in ArcGIS Pro SDK Ideas Last Updated 03-24-2025
2 2
Open
Hello,I'm requesting more API's to deal with licensing.  Either wrap something like what Pro does when there is a lic...
BillSmith
by BillSmith Regular Contributor
in ArcGIS Pro SDK Ideas Last Updated 01-21-2025
1 0
Open
It looks like that editing a feature through SDK (for example a custom button) like moving a point in the correct pos...
FrancescoGiovinazzo
by FrancescoGiovinazzo Regular Contributor
in ArcGIS Pro SDK Ideas Last Updated 01-12-2026
19 1
19
Open
We want to implement a custom MapTool in ArcGIS Pro that selects a Feature on the map, then (OnSketchComplete) pass t...
ghefarm
by ghefarm Emerging Contributor
in ArcGIS Pro SDK Ideas Last Updated 11-21-2024
0 0
Open
It would be nice to have the function GetDataTimeExtent to respect the DefinitionExpression and only the get the valu...
PascalVezina
by PascalVezina Frequent Contributor
in ArcGIS Pro SDK Ideas Last Updated 10-01-2024
0 0
Open
The Workstation Alias can be changed manually or via a registry setting - it is called SessionName there.We implement...
tamasoz
by tamasoz Occasional Contributor
in ArcGIS Pro SDK Ideas Last Updated 04-23-2025
1 1
Open
I'd like to have a new method for BasicFeatureLayer and SubtypeGroupLayer: bool IsValidDefinitionQuery(string sql).If...
PeterVanSchevensteen
by PeterVanSchevensteen Occasional Contributor
in ArcGIS Pro SDK Ideas Last Updated 09-12-2024
1 0
149 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
