Zonal Statistics doesn't support double fields
1411
02-23-2023 04:01 AM
HT12
Zonal Statistics as Table tool doesn't support any double fields. I can't choose them from the list of available fields of feature layer. I've tried to convert the double field into a float as well as trying reduction of fields name, exporting it to another feature, but it was useless. This field has derived from the joined table, but other initial fields in double format can't be used for zonal statistics as well.
DanPatterson
float/double isn't supported as the zone
Zonal Statistics (Spatial Analyst)—ArcGIS Pro | Documentation
don't use a joined input, make the join permanent if you need the input
... sort of retired...
DanPatterson
