XY Table to Points, Long and Lat attributes wont appear
273
10-02-2025 10:58 AM
SeanWillis
Hello,
I am trying to use the XY table to points tool to load in around 2000 data points. Each point has the following data:
The issue is, every time I put the table into ArcPro and try to use the tool, the fields wont even appear in the drop down menu. I have tried changing the cell format in excel before I bring it in, but it does not work as a text field or numeric field. Any idea on how to fix this? I am likely missing something obvious.
Thanks.
DanPatterson
MVP Esteemed Contributor
XY Table To Point (Data Management)—ArcGIS Pro | Documentation
your data are in the wrong format for this tool, it needs
  • Decimal degrees in a geographic coordinate system
  • Linear measurements in a projected coordinate system that use numbers to indicate the position with an x- and y-offset from an origin location
With no text or punctuation or zonal letter designators
See
Convert Coordinate Notation (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
Robert_LeClair
Esri Esteemed Contributor
If you'd like to gain some valuable experience converting XY tabular data a geodatabase feature class, I recommend taking this tutorial first.  Then you may apply that knowledge to converting your data to a feature class.  Create points from a table—ArcGIS Pro | Documentation
