XY table doesnt work if output is outside project gdb
789
06-02-2023 05:14 AM
JonasJansson
When converting coordinates from a .csv through the "XY coordinates to point" and choosing a different output location than the default .gdb ArcGIS pro freezes. Bug is reported.
DanPatterson
XY Table To Point (Data Management)—ArcGIS Pro | Documentation
What is the "bug".  It would be useful
If you don't specify the full path to another *.gdb it won't work, unless you want a shapefile, then you have to make sure that you add *.shp to the file name
... sort of retired...
