WMS to feature class or shapefile
137
3 weeks ago
GIS_User_1996
Hi everyone
Is there any way to convert a WMS to a feature class or shapefile so I can edit the data? I know WFS, but the date I received is in a WMS format and I should be able to convert them.
Thanks a lot for every hint or solution.
Cheers, Delia
RTPL_AU
Honored Contributor
Short answer is no.
Longer answer - A WMS is typically served as rendered image tiles.
I assume you were given a URL to the service?
This means that you can technically 'gather' the tiles you need, at the scale you need, and then convert the raster data to polygon data using various processes.
I have had to print map screens to georeferenced images and then digitise them manually to get the data in a format we could use; last resort option though when the WMS has a lot of weird hatches or fills that make automatic processes slower than just hunkering down and doing it by hand.
The best approach would be to request the actual data in a vector format fit for your purpose, or at least in something half decent.
Depending on your timeline, budget, etc it may require you to purchase the raw data, or lodge a FOI request if the data is from an public agency or similar.
RTPL_AU
Honored Contributor
Short answer is no.
GIS_User_1996
Hi, thanks a lot for your answer.
Yes, there is a URL for the WMS-data. I think I will then request the vector data.
